Thank you Bill, no hard feelings
Your point on using just a switch to direct charging power has also been taken into consideration so don't think I was discarting it either
I am not quite sure why you have two 1/2/BOTH switches or what you are exactly trying to accomplish with them and it seems more of a short term band-aid..... Even with their differing age and your plan to upgrade I would simplify that system by losing one battery switch and putting a simple "on/off" in between the old and new house batts or just lose the old ones altogether.. If the yellow tops pack it in simple flip the on/off to off. Alternatively a third blue top may be the most simple measure to get the capacity you need. Those batteries work they are just light on capacity, which can be fixed by adding more. You have space for four so two more blue tops would be fine and make your system much less complicated.Very crude diagram but will have to do for now.
Hey Jeunesse
I developed a pretty thick skin while in the Army. quote]
.......but were you ever stationed at Ft Polk LA in the 60's...
regards
woody
If you want Agm batteries you should read this link I posted earlier. It describes in detail the care and feeding of Agm batteries if you expect them to last more than a year or two. It is by Maine Sail.I'm not interested in flooded lead batteries, don't want to deal with the fumes and ways of venting. Non spill fully sealed batteries is the way to go in y opinion, I'd go lithium iron phosphate batteries if I could afford it.
