FOlks, After chasing a series of electrical issues by myself, battery charger, power switches, goofy electronics etc, I called in a top electrical tech in the area and he concluded the boat took a lightning hit. His first evaluation indicates around $ 14K to get everything back in order. That's with the proviso, that it doesn't include anything going forward that is identified as a problem. Boat has an agreed insurable value of $ 28 K. Diesel appears fine as does the hull/rigging. In discussion with the local yard, their GM, a former adjuster said: " Assume if cost of repair is above 45% of agreed value the insurer will probably make you a settlement offer in the low $ 20's, declare "Total Constructive Loss" and take boat for salvage. Appreciate thoughts, comments and whatever as I ring the bell in the AM. Lastly, I spoke with my original surveyor, described the events and he concurred lightning was the culprit.
