Need to correct some terminology
It has been my experience that LED bulbs all have the PWM chip in them so turning the power off to the light would also kill the PWM chip.
203
While I will agree there are PWM units that run in the hundreds of Hz range these are top of the line items because tey want a RF quiet solution. MHz PWM are much more common as that is the freq a lot of the chips operate at and the programing is ultra simplistic if all you are doing is turn on-turn-off-...(repeat 1000 times) ...sense-turn on..........
using Mhz freqs also allows the parts caps inductors to be smaller and actually fit inside the bulb.
Ok, led lamps are current driven devices. That means that the amount of current going through them determines the brightness of the led.
The simplistic led circuit is a led with a resistor in series. What does the resistor do? Well, a led is a diode, just like any other rectifier.
In one direction it has very low resistance. Therefore, without the resistor it is a dead short across the + 12 and ground.
So, the resistor is chosen to supply a fixed current for maximum brightness.
When trying to dim a led, you cannot do this with a variable resistor, as you can with an incandescent bulb. What you need to do is send a varying pulse width duty cycle to it, which controls it's peak current. This is where you use Pwm; it is for dimming applications .
When a led is driven directly from 12v with no external resistor, it uses a simple current regulator. Part of the regulator accepts a range of voltages from 12-36 v.
It then puts out a fixed current at a constant dc voltage. It will not be a chopped or Pwm signal. It will be constant dc.
Now, getting to your interference on the VHF & tv.
I suspect your mast grounding. Check that the mast has a solid dc ground.
Also, is your tv antenna masthead mounted?
