Keep it cool and it works just fine,although not exactly cheap.Has anyone used west system six ten two part expoxy that comes in a tube that goes in a caulking gun ?
Crazy Dave, going for the water tight as per your suggestion . It just looked like a good easy way to fill that crack with the tube and caulk gun . Reading about how little actual product there is in the tube was good to know before I bought it .Thats what makes these forums so invaluable .mmsailorll;
check your email as to choice. when epoxy kicks so fast, it is not good to work with either and some tend crystalize when popping off that fast. I still say Water Tite to repair the hull to deck joint. Yes it is a 24 hour dry time but hard as steel when dry and sandable but it worked well for me over the years.
