A have a Hunter 410 and on the DC side of the electrical panel the circuit breakers are backlit with an LED when the circuit is energized. On my panel the LED's are on a circuit board strip and one of the 10 LED's will no longer light.
The circuit board is seeing 12 V and after the resistor to each LED I'm reading ~2 V on those that do light and ~ 1.5 V on the LED that does not light. I've done continuity checks and resistor checks on both the good and bad LED circuits and the only difference I see is the voltage difference. Even with a new LED purchased from Radio Shack I cannot get the failed LED circuit to light while the same purchased LED will light when placed on any other circuit.
I reviewed the prior posts ie the EL strip but this set up ( with the circuit board strip) appears to be different.
Attached are a couple photos.
Anyone have any ideas? Any ideas on the manufacture of the panel?
Thanks
Thanks
