A common question I receive from newbie sailors is " I want to learn the traveler or the use of the fairleads?" or it could pertain to any of the 8 primary sail trim controls for the mainsail or the 6 for the jib. That's a good question but unfortunately it's the wrong one. When I ask them what the traveler, fairleads or outhaul etc is adjusting most times they can't tell me. So, in other words, the correct question would be "what is the sail trim control actually adjusting?". Additionally, some of the sail trim controls adjust a couple of things and the fairleads adjust EVERYTHING on the jib.
It can get a bit confusing for newbies. They push or pull some sail trim control and they get a results but the action causes another event they weren't expecting.
I've taken the confusion out of the equation. I've developed a QUICK REFERENCE that lists ALL the sail trim control for the main and jib and identifies what each sail trim control is actually adjusting. Additionally, the quick reference tells you which way to push or pull the control to obtain the result the sailor is seeking. The best part is this reference is provided FREE when you purchasr the SAIL TRIM CHART.
