While I agree with the rest of your post, this part's something that needs to be reconsidered. Many Facet approved electric fuel pumps have tiny filters on the bottom, and most builders made the mistake of putting the fuel pump before the primary fuel filters. The purpose of the primary fuel filters is obvious. The fuel pumps should go after the primary filters.
yes, in fact, it really should make no difference where the aux pump is located, as long as the fuel runs thru the main filter system BEFORE it goes to the injectors or injector pump....
the original engine mounted mechanical lift pump is inline BEFORE the filters..
the primary filter is the first filter in the system, but not the first component. its purpose is to catch the majority of the water and debris... the secondary is a finer media and is suppose to catch whatever makes it thru the primary... if the primary is changed timely in a normal, reasonably clean system, the secondary should only need to be changed every other time... if its getting dirty and restricting the flow, the primary is not doing a proper job....
almost all electric fuel pumps that are readily available are meant to push fuel, rather than suck it... so it should be mounted as close to the tank as practical.
the pumps that are designed for suction are more expensive, and usually special order....
but this is not to say at the level of fuel vs the height that it needs to lift the fuel, that a common pump would not be adequate, but sucking fuel thru filters that may be a bit waterlogged, or otherwise have some small restriction is asking a lot from a push pump... as they dont prime them selves very well, but as long as they have something to push away, a natural vacuum will bring up the fuel from the tank. (we would like to assume the fuel and filters will always be clean and fresh, but sometimes this is NOT the case)
and in addition to this theory, if upon changing the filters, with the fuel pump after the filters, if you dont get a good seal somewhere, you will have an air leak that will prevent priming... 'cuz it will suck air in and not fuel... and will be hard to find.
if the pump is closer to the tank, it WILL prime the system, and any loose filters/fittings will show quickly as a fuel leak. tighten the problem area and go...
we can never know what the situation will be when the aux pump needs to be used, but if its located in the optimum location in the system, you can cover all bases..
