Empty your water tanks and see if you still get water in the bilge after rain or hosing down. Most likely leak is the stanchion base bolts. Can you pinpoint by taping over limber holes and watching where water accumulates? Unlikely to be hull to deck join unless damged as Beneteau do a good job bonding these together. I have had success pressurising the interior by rigging a shop vac to blow into a hole in a false companionway board, sealing all outlets and using a soap solution around deck edges and fittings. Andy Copeland
