I just bought a J-37 at a steel. It has no electronics at all. It was laid up about 2 years ago in a heated/AC building. The survey showed very little needs worked on. 2010 boat was put through a complete refit/make over where owner lived. All stainless fittings replaced with a bronze base metal. Mast was rewired with all new fittings. The heated building is nice to do the small things that need cleaned (electrical connections and etc) or repaired (seals and etc).
What is the minimum electronics I need to be safe sailing? What would be nice to have? What would be good to have 2 of? I will go back down the Ohio to Mississippi to the Golf then hopefully the BVI.
I do want a longer range radar 80 nm or better but don't know brands. The electronics was removed by the son who had a house invasion losing the electronics.
