1994 Hunter 40.5
Below are some pictures of an area I need to reseal. The first picture is of the sealant around the large fixed cabin port. As you can see its a black flexible material. It currently does not leak unless its a real downpour and then only a drip or two. The window appears to be well bedded. The second picture is with me holding it up as it is loose in the groove.
What kind of sealant do I need to use here and are there any special tips for installation other than clean out all old caulking. What prep cleaner should I use and what sealant. Obviously NOT 5200 but I am sure there is some correct product. Thanks in advance
