New to me Catalina 30
Sep 1, 2013
53
catalina 30 suttons bay
Hello all, I just picked up a great 1980 Catalina 30 TRBS. I have a lot of questions. First I have been reading that the 11hp diesel is underpowered , probably solved by changing props ?. Second, does anyone make an adjustable traveler ( aft location) just a few questions . Kind regards, Shannon
dj2210
Feb 4, 2012
337
Catalina 30 Watts Bar
Enjoy the boat. Where will you be sailing? Your 11hp and prop is probably fine depending on where you sail. Garhauer makes travelers that are used on Catalina's. What do you have now?
azguy
Aug 23, 2012
337
Catalina 22 Lake Pleasant
Most travelers on C30's is my area are on the cabin top
Sep 1, 2013
53
I sail on grand traverse bay- Lake Michigan . I have an aft traveler now that does not have adjustable cars, which I need to Change ASAP
Jul 1, 2004
398
Catalina 30 Atlanta GA
Congradulations.
Your Universal 11 will do just fine on Lake Michigan with a two bladed prop for getting you out to your sailing area and back. A three blade will not not necessarily make your boat faster. However, if you encounter rough weather and plan on hauling butt back to the harbor keep in mind that you will need to give yourself more time as the 11 hp is not known for its blazing speed on these boats. The 11 hp was replaced by the M-18 (16 hp) and then by the M-25 (22-23 hp). Catalina finally got it right with the M-25.
You have no tides nor currents to contend with.
enjoy
Sep 17, 2010
26
Catalina 30 Anapolis
I recently replaced the so-called 12 hp (more like 10) Yanmar YSE-12 on my 75 with a Beta 16 2-cylinder with a 3-blade prop. I've gone 7.1 kts at 3,000 rpm. Flat water, moderate breeze, Chesapeake Bay.
That engine fit with no alterations to the engine compartment, other than moving the side hatch to the front for better access. No bump under the dinette seat, used hi-rise exhaust, etc. Like it was made for the boat.
This is a frequently recurring topic. You might want to try a forum search (top blue tab) and try "11 hp" and other criteria for earlier discussions.
Good luck. In general, skippers with these engines found them adequate for most conditions.
Jun 29, 2011
142
Catalina 30 Mk II Gibsons
Congrats on your purchase, what hull # are you?
I have the M25XP, but seldom use it a full throttle, so you should be ok.
Post up some pics.
Nov 14, 2013
238
Catalina 30 MkI 1983 TRBS Westbrook, CT
Congratulations!! I'm in the same boat (no pun intended) althought I'm lucky and have the M25.
Good luck!
jrowan
Mar 5, 2011
1,294
I also have the 11 Hp diesel on our 1980 C 30. First, I have debated whether to replace the prop, but you really risk over torqueing an old engine, & over taxing it & causing extra transmission wear. Second, there is not a lot of clearance between the hull & the existing prop as it is mounted rather close to the aft end of the keel, rather then close to the rudder as in many other sailboats. THe engine is adeqaute for most conditions, & I agree with Bob that you don't have tides to contend with on the Great Lakes as we do in open water.
The C-30 is a great boat, & the trade off in smaller engine is worth it, as your tall rig should perform well under sail, & that's what really counts anyway. We did after all buy a sail boat, not a power boat, right?
Lasty, make sure you inspect the wooden bow sprit for cracks & rot & if you have the wooden spreaders on the mast have them inspected aloft for rot. Spruce is good wood, but doesn't last forever. Since you forestay is attached to the sprit it is kind of important. As far as your aft traveller, try sailing with it first before replacing it, becuase it is a lot easier to adjust next to the helm when single handed. Just watch your head when tacking or jibing!
Good luck & enjoy your classic.
jakez
Nov 19, 2012
25
Catalina 36 Santa Monica, CA
I have the Universal 5411 11hp with a 3 blade prop and run it out of Marina Del Rey... I have no issue with the power. I can run about 6 knots under engine only in calm seas and moderate wind. It think the 5411 would probably be too little power if you're dock was up a river, etc. In a current, it might be a bit light.
My 3 blade, from what I've noticed compared to two bladed props, gives me more low speed torque / maneuvering power. I can change the boats direction quickly -- ie, when coming into a leeward slip a bit spicier than planned, etc.
Congrats... fun boat with lots of things you can do to it.
jrowan
Mar 5, 2011
1,294
With a clean bottom I can also move our boat along with the 5411 at close to 6 knots in calm water. So I wonder how much more speed you really gain from the the third blade.
I'm sure you do get more torque at slower speeds & possibly a knot or so of potential extra speed. But remember that whatever speed you gain with a 3 blade prop is also increased drag under sail, & we are after all supposed to be sailing out boats, right?
I don't know for certain, but an extra blade of resistance could cost you a half knot or more under sail. As far is motoring, we check the tide schedules & try to sail out with the tide & sail back to the marina with the prevailing wind & tide with us & not against us. This makes a huge difference in the speed & efficiency of the boat sailing where you want to go in a timely manner. This is true for any sail boat. Sailing with the wind & tide can add two knots to our speed, or if the tide is against you can rob you of the same amount.
My advice to a new sailor is to try out what you have & learn to sail the existing boat's set up, before attempting to make expensive changes that may or may not improve performance. A $75.00 hull cleaning by a local diver is the cheapest way to immediately improve the performance of any boat under power or sail.
1dandy
Jan 27, 2013
7
Catalina 30 Wiarton ON
Congrats and get ready for a lasting relationship with the Cat.
I changed my two blade for a three blade because of menouvering problems in the slip area and not for speed. I sail it. The three blade made a great deal of difference and in windy conditions coming and going from my slip is a breeze pardon the pun.
Dandy
Sep 1, 2013
53
Thankyou ! We're excited for a larger boat, I'm going to miss our current boat ( 27 ft S2) but our family is growing so we have to go bigger. I am without a doubt going to switch to a 3 blade prop. Not really worried about the drag:). When I want to go fast I'll go jump on a race boat ( 1d48) ! Kind regards , Shannon
jrowan
Mar 5, 2011
1,294
Shannon, That's a funny coincidence. Our previous boat before our current C-30 was also an S 2! We had a 1980 S 2 8.5 meter (28 feet) which was very similar / same as yours. It was a great boat, but a little too small down below for a family of 4. The funny thing about the auxillary power was that the S 2 only had an 8 horse power 1 cylinder Yanmar diesel, so I feel right at home with our still under powered 11 horse Universal diesel in the Cat.
She sailed great though & was very well built, but alas I tried to stretch her out in length & width, & wound up with a Catalina 30. Cheers.
Sep 1, 2013
53
That is funny! I'm really going to miss our S2. Performance wise, I know the c30 will not compare, but this is a family cruiser. I'm blessed to be able to race on quite a few boats where we live, so I'm just fine trading speed for more space :)
jrowan
Mar 5, 2011
1,294
Shannon, I must agree that the S 2 line of sailboats are indeed faster then Catalina's are.
Although when the bottom is clean, the sails are in good condition & trimmed right, & you don't have an excessive amount of stuff stored below or full water tanks, etc. she can actually move at a pretty good clip of speed. My S 2 was able to rocket up to about 8 knots when running with the current. I have been able to get 7.2 knots with my C 30, which ain't bad for a boat that is about 2,500 pounds heavier then my S 2. I do feel that the Catalina 30 is a stiffer boat under sail, is more stable & stays on her feet better. Plus the huge amount of space down below cannot be beat in a 30 footer. I've sailed boats that were 35 footers that did not have such a good use of space in the cabin. We love our C 30, & until my ship comes in, I cannot think of a better 30 footer to own. Cheers.
Sep 1, 2013
53
Couldn't agree more, we cannot wait for the additional space. As far as performance goes , I know she is no slouch, I've already ordered a New main, genoa and asym. ( Carbon / technora) and 3/4oz ). So I'm excited to see what I can squeeze out of her!
