Hey Guys,
I don't usually start threads. Albeit, this is probably long in the tooth.
I mostly try to be helpful (Thru my OWN trial & error) to be of some assistance for those who pose the questions. However, I am seeking some feedback on this UNENDING PROBLEM I am experiencing & all replies are greatly appreciated.
I have a 1980 C30Mark II (built in California). I have been trying to stop leaks thru my portals for thirty+ years now .....And I am not a happy camper/sailor.
I have spent my professional life in the mech/electrical fields. From petro-chem to nuclear & civil disciplines. I have well varied field experience, hence my designs/upgrades take into account construction, maintenance & equip. & changeouts. This is how good design is achieved.
My portal problems are two/three pronged. Herein lies my questions:
My C30 has four portals per side, 4 STBD & four PORT.
Vertically, I have a TWO piece (lateral, 1 top, one bottom) external outer frame (w/glass & rubber seals). There is a one piece inner "collar" flat flange for tightening (internally) against the outer two-piece exterior flange. This was a design meant to fail from the beginning. Maybe it was a cost factor, but a poor way to proceed.
The other problem is I discovered how can one tighten a two-part flange outer shell portal (2 piece) frame when there is NO CORING between the inner cabin liner & exterior cabin (2-piece) flange. This surely was a quality control issue.
One could tighten until doomsday and the "squashing" between the outer shell & inner interior liner is a failure in terms. Thus designed to fail, due to non-coring fabrication practices @ the time (1980). How can one seal when one cannot SEAL if not having a fixed & constant solid surface? I don't know if other owners had this problem.
I realize 1980 (in boat years) is a century away from now-a-days boat building (and that's fine, it's onward & upward), however, this has been a never-ending battle in keeping outside water from invading my boat thru my portals (5 times over). I have reviewed the Catalina Direct replacement window system, but I do NOT trust Lexan (or equal) as a replacement. I view this as a band aid fix & not THE correct fix. Search Lexan & UV attacks..........
So, my question is thus, have other owners experienced these same problems & did they find a better ONE-TIME FIX? This is my FIFTH TIME in 30 years, at trying to make my portals waterproof, while keeping the original portal parts. Let's not forget the MISSING coring. QA didn't exist in 1980.
I know my fellow 1980 C30's feel the same, so chime in brothers.................
CR
CR
