We put our Mac 25 in the water yesterday and when I raised the mast I found a troubling problem. The port side lower shroud has a single strand that has somehow been severed about two feet above the chain plate. Yikes. The best I can figure, it must have been pinched somehow while the boat was in transit. There doesn't seem to be any other damage at all to the cable, but it's obviously going to need to be replaced soon. I know these cables are rated for WAY higher pressure than I put them under when sailing, but I certainly won't be going out in anything more than light wind until it's fixed.
Replacement seems like it should be easy enough. Stainless Steel cable with standard crimping. I used to rig massive speaker arrays to hang from ceilings in concert venues using the same stuff. Does anyone have a recommendation for where I might find the stainless cable at a reasonable price?
