Cabin lights on 2000 Hunter 4608
drtsr1
Nov 14, 2013
52
Hunter 460 Palm Beach
I just closed on a Hunter 460.. I need to change the bulbs in a few of the over head lights. I just can't figure out how to access the bulbs. They are round maybe 2 inches across.
Thanks for any directions you can provide.
Rick:confused:
Mikem
Dec 20, 2009
823
Hunter 466 Bremerton
The plastic ring around the light pops off. Use a small knife blade and gently work around the ring. Be careful when the ring comes off as the frosted glass is only held in by gravity.
KD3PC
1,069
boatless rainbow Callao, VA
I would strongly suggest using the LEDs while you are there...much lower power needs, and better light.
Best of luck, and enjoy!!
drtsr1
Nov 14, 2013
52
I would like to but they seem to be very expensive: $23-$33 each...
If you know a place with a better price it would be great.
Tantor
Dec 25, 2010
85
Hunter 410 LaSalle, Mi
LED
I bought from ebay (Honkong) cheep and they work great
search ebay G4 LED 12vdc there is a lot of choices...
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
Make sure the ones you buy are good for 13.5 volts. They cost about $3 each rather than $1.
lnikl
Mar 1, 2011
88
Hunter 38 Port Moody, BC
I would concur with the advice to go with LED throughout (~8 fold decrease in power draw). When choosing bulbs, in addition to the good advice already provided, I would also recommend that you go with warm white LEDs. The cool white bulbs seem a bit brighter but will make you feel that you are in a clinic awaiting a procedure rather than being in your place of joy. I have tried out both and I would only ever put warm white in my boat.
rgtet
May 31, 2011
25
Hunter 380 Herrington Harbour North
I replaced all of the puck light bulbs with 10LED warm white G4 bulbs from MarineBeam.com. I avoided the Chinese stuff that is much cheaper. The posts need to be trimmed a bit to fit the wafer into the fixture, but it's been a huge improvement in power draw and light in the cabin. They were about $15/wafer.
