I’m planning on installing solar panels (around 300 watts) on my boat in the spring. I’ve done a lot of lurking on solar threads on this and other sailing sites and also on solar energy forums. Opinions about controllers for small scale systems (<600 watts) seem to vary a bit between the sailing and solar forums. The general consensus of the sailing forums seems to be that, if the budget allows, MPPT is always the way to go as it will make the most out a limited amount of real estate on a boat. The consensus of the solar forums seems to be that while MPPT is nice to have, the real-world performance difference between a high quality, programmable MPPT controller and a similarly high quality, programmable PWM is so negligible for a small system as to almost never justify the added cost of MPPT, even when panel real estate is limited. The solar forum people also generally say that those who claim significant performance boosts by changing from PWM to MPPT probably aren’t comparing apples to apples – that they probably swapped a low quality, non-programmable PWM for a good quality MPPT and are simply seeing the “boost” from no longer undercharging with a “one size fits all” charging sequence. I’m certainly paraphrasing and generalizing the arguments made on both sides, but that’s what I’ve taken away.
I had initially been planning on going with PWM, then became sold on MPPT, and am now back to thinking a Tristar 45 PWM would be my best bet. It really comes down to real-world performance. If there really is a “boost” from MPPT of 5 or 10 AH or more daily average, I can see its value. But I’m just not convinced I’ll see that theoretical gain “out there” and it seems like the extra cost of MPPT might be better put toward conservation. I’m probably already over thinking this, but am I coming at this all wrong?
Keep in mind that MPPT only really benefits, and has a good advantage, when your batteries are in bulk charge. With approx 15A +/- of current available you will be in bulk MOST OF THE TIME... Thus you will be benefiting from MPPT most of the time you are charging with solar or well into the mid 90% SOC range depending upon bank size..
I have and use a device that I track and compare solar performance with, a custom built PentaMetric monitoring system. MPPT wins on boats but the gains are usually less than 15%, unless conditions are perfect.. Still this is an excellent boost when you are out of real estate which most boats run out of faster. On boats I have yet to see PWM beat MPPT, not once, and my monitoring equipment is simply an impartial observer......
PLEASE DO NOT BUY AN eBAY SPECIAL MPPT.... There are many algorithms for MPPT and some really SUCK. The controllers I like best are the small Genasun's. the Rogue Powertech and Morningstar controllers. Rogue just launched a brand new 20A model for $250.00 which looks really, really nice. You really can't beat the Tristar 45 MPPT or the Rogue.. Theya re both very well executed products. IMHO you get more for your money with Rogue....
You need to be careful when trying to read solar forums and boat forums on solar. If you read only off-grid solar than the conclusions can be closer but grid tie etc. forget it not the same type of use.. Ohm's law does not change but they way we use it, the way we wire it, the panel angles, temps and the voltage we use them at do.. In off-grid panels are often wired in series vs. boats which are usually parallel to avoid shading issues. This changes things. Panels on roof tops get very hot where panels on boat davits etc. stay considerably cooler thus allowing higher voltages... Our panels are also not directly aimed at the sun which also helps them run cooler but also digs into overall performance.
In short it is rare that I install a PWM on a boat system that is over 100 watts unless there are extreme budget constraints..
This simulation below was to show the difference in bulk between a shunting controller (PWM would do exactly the same) and an MPPT. Keep in mind that your solar panels performance would never stay as static as my power supply. Good quality MPPT controllers use a P&O or perturb and observe algorithm. I like to call it a hill climb algorithm. This means it is constantly testing the maximum power point to see if it can covert more voltage to current. It does this by pushing up and up and up until it can't go anymore. The calculations are done on the fly and no measurable
pauses exist in current delivery. They do this by testing the voltage very rapidly multiple times per second. You can see how fast the Genasun is doing this by watching the Fluke meters current reading.. It wastes no time in the algorithm.. Cheap Chinese controllers shut down, observe panel voltage, then re-start. On some real cheapies this can often mean worse performance than a PWM.
