H34 Rudder size?
Jul 28, 2013
126
Hunter 34 Holland, Mi
I have been reading and have found there was a rudder recall on early H34's. I would like to know if my rudder has been updated. If someone knows what size the newer rudder should be that would be very helpful.
Mark48
Mar 1, 2008
166
Hunter 34 Milwaukee
After doing a quick internet search, I would suggest contacting Foss Foam as they are supposed to be suppliers for Hunter, they should be able to give you the correct size and price(s) pending lay-up.
Oct 14, 2005
2,191
a65sailor...
What year is your boat and hull #? The early '83's were fitted with the H31's rudder, which was the subject of the recalll. The H34's built after '83 have the larger rudder.
Jul 28, 2013
126
The boat is an 83 the hull number is 34268m83. I'm not sure where that would fall in the production run for that year. If you know I would be interested in finding out. Thanks
Dec 14, 2003
1,442
Here a pix of my 84 being launched where you have a good view of the rudder. Knowing the bottom is 16" you can scale and get an idea of the full size, then measure yours and compare. I assume it is on the hard. Mine being an 84, it is the larger rudder.
2,191
a65sailor...
Attached is a pix of my rudder on my '83 H34, hull #113. This is the original rudder as far as I know (being 5th owner). Note the difference in the aft end taper compared to Claude A's.
Also, earliest '83's had Westebeke engines. Mine's a Yanmar.
These are the two major production run changes for that year that I am aware of.
