Trickle charger
Oct 4, 2012
34
Anyone know a good way to store the house and engine batteries over the winter?
Should I keep both batteries hooked up to a trickle charger for the whole winter until it's time to reinstall them?
Are there chargers that accommodate 2 batteries at a time?
Thanks -
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
Just be sure that they are fully charged, disconnect them and leave them in the boat..
Gunni
Mar 16, 2010
5,937
I leave mine in the boat. Charge them well before haul-out, and plug up the boat to shore power at the yard, and turn on the house battery charger circuit when I visit. Throw the house load battery switches when you are not aboard.
Jul 8, 2005
522
Jeanneau 389 Grosse Pointe Farms, MI
I used to take them out of the boat and then realized it is not needed. Have left them on the boat for years. Just disconnect the cables from the terminals after they are fully charged.
Oct 4, 2012
34
Thanks, any downside to leaving the cables connected to the batteries throughout the winter?
11,722
There is a very high percentage of boats with "parasitic loads" even with the battery switch in the OFF position.. Battery monitors, electronic bilge switches, propane sniffers, stereo memory etc. that can all drain off the batteries over the winter. Just charge to full then disconnect the positive or negative cable leads from the batteries.
Tejas
Dec 15, 2010
164
Beneteau First 36.7 Lake Travis
As Maine Sail describes apparently a paradoxical example of "parasitic Load" is a battery monitor -- sucked the batteries almost dry before we figured our what was happening.
Sep 13, 2013
74
Beneteau Oceanis 41 Seattle
For boats left on the water, you typically need house batteries connected for the bilge pump to work. Any downsides of leaving the batteries permanently charging on shore power? Other batteries (like engine and bow thruster) technically do not have to stay connected, so there is a choice there.
hewebb
Oct 8, 2011
329
Catalina Catalina 25 Joe Pool Lake
If you have power available, install a battery tender. Be sure water level is good. I have been using them for years on things that are stored for several weeks or months. Unfortunately, it takes one per battery or a double for two.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
hewebb: What are you referring to as a "tender"? If its a trickle charger it will work on multiple batteries, but will split its charge current based on each batteries demand at a given moment. Of course there is a limit to how many batteries the trickle charger is capable of handling effectively. I commonly use one for 2 batteries and have never tried more batteries on it. Chief
Nov 26, 2012
2,315
Beneteau 321> I have no problem with that but Maine Sail advocates only periodic recharge. I am gone for 3 to 4 months in the winter so I use a trickle charger across 2 ea 100 ah batteries. Have done this for years and my batteries last much longer than other sailors and RVers batteries. I think proper maintenance is the biggest factor in how long your batteries hang in there! Chief
Sep 8, 2013
71
Beneteau Oceanis 45 Rock Hall, MD
Do a search for BatteryMINDer, I use these on my car and boat batteries. The ones I use seem to have been discontinued but the replacement seems to be the Model 1500. I first heard about BatteryMINDer in Aviation Consumer, a periodical from the same publishers as Practical Sailor. They have tested a number of different battery chargers and these are the ones they like best. They also pulse charge for desulfication.
Nov 26, 2012
2,315
Grouperhound: What is the max amp draw on these chargers? The pulse aspect seems like it would be good. Chief
