I am slightly familiar with the Balboa 20, but is this boat a Balboa 20, or an Ensenda 20, or a RK 20? All had same hull, but the deck and, I think..interior were different on the Ensenada 20 and one of the RK 20 versions (the RK 20 came in 2 different deck styles, in reality....one was the old Balboa and one was the old Ensenada). Your interior appear to match the pictures that I have of a RK 20 (the "Ensenada 20" version).
Anyway, my experience is with a CAL 21, this was of the same vintage as the Balboa/Ensenada 20 and was, like them, a retractable Keel boat. On the CAL 21 the keel-trunk did flex a bit side-to-side, but was restrained by the structure of the main bulkhead/galley counter/head compartment that spanned the boat and pretty much took the forces of the keel, mast, and side-stay loads. Fiberglass is flexible, that is it's nature....but like any material, too much flex causes fatigue of the structure and may lead to failure. The CB trunk on my old 12' O'DAY Widgeon also flexed a bit, side-to-side, on that small boat no side-bracing was needed, but the whole boat plus her skipper (me) weighed less than your keel probably does.
So, I would think that some kind of bracing does need to be there in your boat. A little flexing is not fatal, but I can't see how the keel trunk as shown in your pictures would possibly be restrained enough to not flex more than what should be. You need to replace that rotted plywood structure for the berths and I would think..add some kind of knees (bracing) on each side of the keel trunk. possibly linking ot the berth structures.
I've added some pics that I found of a RK 20 in only slightly better shape than yours, and to compare.... a couple of pictures/drawings of the CAL 21
