Acoustical foam
Mar 22, 2004
733
Hunter 30 Vero Beach
I'm looking for a reasonably priced source for acoustical foam like the product used in the engine compartment of my 83 H30. I've looked at the stuff at Auto Zone and Advance Auto. Not really what I'm looking for.
Jan 4, 2007
406
Hunter 30 Centerport
How much do you need?
The sound instillation on my 83 h-30 is also dissolving into powder. But is 12 sq feet in the suggested kit enough ?
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
Last winter my wife and I glued the barrier with the lead middle to the ceiling of the engine room. Nasty job but we managed to keep stuff covered with plastic. I did get plenty glue on me but the results have been great. We still have a small area on the bulkhead left to do. I used G-Flex epoxy on the holding pins and then wrapped whipping wire around the pins as additional support to the acoustical foam. Here's a pic...
All U Get
6,244
S2 9.2a Fairhope Al
Does anyone think the self adhesive would make life easier? With all of the oil that was sprayed everywhere, I'm wondering if I would be able to make it stick.
go the auto parts store and get some break parts cleaner in a spray can ...maybe 2 cans ...place some old towels at the bottom of the bulk heads and spray the infected are ....it will claen up nicely and then the glue on the foam will stick...through the rags in a water filled bucket for discarding .......word of caution no open flames while doing this.....
this is not the only way to do this but it is one way ......
regards
woody
I'd add ventillation to the caution list..... you could get very stoned very fast (and not in a good way) if you aren't careful. Lowes sells respirators for use with oil based paints and epoxy etc. You can also buy them at James T. Davis. They are made by 3M and cost about $40. I use them anytime I'm doing epoxy work.
But I think the idea is a good one. Some cheap carbeurator cleaner and a pile of rags and you will get the surfaces very clean and ready for some adhesion. You might also want to try some of that two sided carpet tape. If you have never used the stuff it is extreamly sticky and the "tape" is actually a 1" strip of fiberglass tape. Run strips of that along the "ceiling" of your engine room and then put it up. Stuff is only $5 at Walmart
Oct 20, 2013
65
Hobie,Venture hobie 16,V21 Carlye lake
You may consider going a different route, Dynamat. I have used this in my cars and like the results, it bonds very tightly to the surface and will not crumble like foam. It absorbs the vibrations and noise as well as a heat barrier. If you have a stainless steel sink you likely have a similar product fixed to the under side.
CarlN
Jan 4, 2009
603
Ketch 55 Bristol, RI
I've never heard an explanation as to why some sound absorbing foams turn to dust and others don't. Pulling out the bad kind is a miserable job.
Are there two different kinds of foam chemistries used or is it just a quality thing?
Oct 20, 2013
65
I am trying to remember a instance of 30 year old foam that was still good, from my limited experience with old outboard cowlings they all fail and start to fall apart. Maybe it is the glue that breaks down the foam or maybe the hot and cold cycles, who knows. I do remember a 1976 Cutlass with a headliner that liked to fall on my head and blown foam in my eyes, good times.
