An Australian compass that points backwards in the northern hemisphere, which way does it point in Australia ?
We are in Oz and North is STILL North even with our U.S. compass and the water down the sink goes the same way around!An Australian compass that points backwards in the northern hemisphere, which way does it point in Australia ?![]()
I was in when the last were decom'd. Never rode one but still I served with quite a few DBFers :dance:DBF!
I hate to admit it but my chart plotter is my primary navigation instrument.I find it interesting that the compass is being refereed to as a backup nav instrument. What are you folks thinking is your primary nav instrument?
Anyone making a passage across a major ocean current in a slow moving vessel will want to use a compass so that they can navigate in the most efficient manor. Consider a Gulf Stream crossing from Lake Worth to West End. The distance is approximately 50 nm and at 5 kt the passage will take about 10 hours. In the stream current is about 2.5 kt setting to the North. On average a navigator can estimate 2 nm per hour set to the North on the Lake Worth to West End passage. Therefore by using a compass heading to a point 20 nm to the South of West End will result in a track that is somewhat "S" shaped ending at West End. Now on the other hand if one used a GPS set to West End, the heading would be the course actually traveled by the vessel not the direction the vessel is pointing. Thus as the Gulf Stream set the vessel North the autopilot or helmsman would compensate by turning into the stream. The GPS will cause the vessel to battle the Gulf a Steam where as the Compass will allow the vessel to take advantage of the stream.Official dis of the compass. In my airplane I have two GPS and two IRS ses ( Global Positioning and Inertial Navigation)... I have a standby compass and that is what it is.. an emergency data base to monitor... but I havent yet in 32 years of flying and sailing. Seriously! Yeah it is on the binnacle. I KNOW how to use it... do I? Never. And if you people who use your compass havent done a "swing" to calibrate your deviation and variation then you will be the next grounding! Come on seriously, you people sail by a compass? How about buying a boat that was built after the turn of the century... 1800 I am floored. Think there is some serious BS in these responses. Sail to where... your jetty, favorite anchorage, compass.... I know Joshua would probably roll over but did you all know that there have been multiple circumnavs without paper charts? Set and drift is a thing of the past. IMHO. Sheesh... know how to read it yeah but enter the jetty in the fog on your compass... looking at your chart and your ELECTRIC depth finder.... I have three GPS's and a compass... which one loses. Troutman if you find a free compass on Criag'slist grab it... otherwise put the money towards a half kite! This is just bizaar. If you run out of all the above options its called Tow Insurance!
Agreed. And it is completely underutilized. Please put mine on the mast with big digital numbers.Its very strange that many think a compass is only a navigation instrument when one of the chief functions of a compass is a sailing instrument, especially when close hauled.
hvbaker's info is definitely right on for crossing any large bodies of water that have strong currents. For the Gulf Stream in the Straights of Florida, If you use and follow your GPS output to your destination waypoint you will definitely buck the current for most of the crossing, using your compass instead will cause your boat to 'squirt' across the Gulf stream in a soft "S" course trajectory and your total travel time will be considerably less.Anyone making a passage across a major ocean current in a slow moving vessel will want to use a compass so that they can navigate in the most efficient manor. Consider a Gulf Stream crossing from Lake Worth to West End. The distance is approximately 50 nm and at 5 kt the passage will take about 10 hours. In the stream current is about 2.5 kt setting to the North. On average a navigator can estimate 2 nm per hour set to the North on the Lake Worth to West End passage. Therefore by using a compass heading to a point 20 nm to the South of West End will result in a track that is somewhat "S" shaped ending at West End. Now on the other hand if one used a GPS set to West End, the heading would be the course actually traveled by the vessel not the direction the vessel is pointing. Thus as the Gulf Stream set the vessel North the autopilot or helmsman would compensate by turning into the stream. The GPS will cause the vessel to battle the Gulf a Steam where as the Compass will allow the vessel to take advantage of the stream.
On my vessel I have three compasses, one at the helm, one at the Navigation table, and a hand held and two GPS one at the helm and one at the navigation table.
For serious sailors on passage there are still very real advantages to navigating by compass heading rather than GPS headings.
