Jackdaw, I did a bit of searching around regarding the asym "dick" and some folks say the correct term is an asymmetrical gybulator. But, I guess it looks like a… well, you get it. Some say it's a couple layers of stiff webbing sewed together, other say a layer of webbing, a plastic batten, then the sail, then another layer of webbing, all sewed up.
Some guys say they cut them off because they get hung up on lifelines. Other guys always gybe "inside" and don't need 'em. I figure you're more likely to gybe inside if you have an extendable bowsprit for the asym.
I totally see how it works, projecting up and off the luff right on the tack patch of the asym.
On my small dinghy, racers often have a bit of wire coming out front of the stem head fitting, and angled up. It serves to catch the symmetrical spinnaker sheet when the chute is not hoisted, and prevent it slipping down into the water because this class has an almost vertical bow with the stem head fitting all the way at the tip of the bow.
On my cruising boat, I have a bow pulpit, so since I've never noticed my asym lazy sheet falling into the water; I'm thinking it tends to get caught on the pulpit. But I'll be looking out this coming season, and if I start to see troubles, now I know I can put a gybulator on!
I love picking up new ideas like this, thanks!
Brian
Brian
