OK i have just installed my type c panel after building an engine harness to my 2gm20f in my 9.2a.....now for the brick wall part of this.....the positive terminal is for the positive side of the starter/battery......the E terminal is for the negative side of the battery.....simple so far .....now there are also 3 spade connectors on the back....one on the upper left side marked N and running vertical ....there are 2 spade connectors on the upper right side running perpendicular to each other ...vertical on bottom and horizontal on top....with no markings ....so my question is what do they hook to......i have a pic at the bottom of the page.....any help would be appreciated....
regards
woody
regards
woody
