Chartplotter mount
Percy
May 2, 2011
7
Hunter 31 Rochester
This spring I want to mount my new Lowrance chartplotter to the binacle guard on my '85 Hunter 31. It should be simple, but i wondered if there's any advice out there,
Thanks
This spring I want to mount my new Lowrance chartplotter to the binacle guard on my '85 Hunter 31. It should be simple, but i wondered if there's any advice out there, Thanks
Mount It so it swivels and tilts so you can control the reflections of sun and off the water.
Oct 14, 2005
2,191
Percy...
Here's a pix of the backside of my chartplotter mounted on a wood base attached to a lock-block on the binnical hoop. It can swivel side-to-side and tilt to be seen seated or standing. The lock-block premits it to be removed when not in use or when away from the boat.
4,247
Hunter 40.5 Warwick, RI
Years ago I build a fully adjustable mount for my Raymarine radar display. It was meant to be "temporary" until I had time to build something more esthetically pleasing.
In the true spirit of "What is forever is temporary and what is temporary is forever", I used this mount for 12 years. The mount clamped around the pedistal guard and the manufacturer's U-mount attached to it.
Perhaps you can make something like this if you can't find a ready-made mount that you like.
