Lowering mast to precisely 16' what angle 45 degrees??
Nov 19, 2013
34
Hunter 23.5 Tampa
I Like the winch lowering technique, I've read where they use a Gin pole... what is this?? I have a hole in the base of my mast is this where the pole is inserted for the lowering of the mast... What size winch is needed to overcome the hardest part of the lift.
Jun 2, 2004
3,672
Winch
No winch is needed you use the main halyard on the 23.5. It has a 4:1 purchase. The first couple of feet are a bit of an effort then it is fairly easy. I could be on the water in 30 minutes after pulling up to the ramp when I was trailering mine frequently.
Get the manual and see how the system is set up.
Jul 1, 2010
990
Catalina 350 Port Huron
Forgot to mention plenty of restaurant docks on both sides of the bridge that could be utilized to carry out this exercise!!
If they have outside dining you could be the entertainment, especially if you don't make it :)
Seriously, get the gin pole for your boat and drop the mast using the main sheet and jib halyard. Stow the mast between the mast crutch and the bow rail. It's a piece of cake to do this and you'll have no worries on your trip.
If you have to do this every time you want to use the boat, I'd find a different place to keep it.
Nov 19, 2013
34
Hunter 23.5 Tampa
65 degrees for lowering it as well??
Would the calculation remain the same for lowering the mast??? I was going to design a crutch that would hold it at the prescribed 16' mark... do you think while sitting in the crutch two lines port and starboard to give it some lateral support????
Thank you for your answer in advance....
Holy cow that did it for me.... wow 65 degrees is way over.... same applies for lowering it as well it has to come down 65 degrees if you lowered it in any direction correct??? I was watching the video holy cow doesn't come down smooth.
OK. Lets assume your mast top is only 35 feet above waterline. Your boat has to come to 24 degrees from horizontal to clear, or SIXTY SIX degrees of heel.
[/quote]
Nov 8, 2010
11,386
Yes no matter what direction or method (heeling or lowering) The mast will have to be at that angle (or more).
Once the shrouds go slack they offer NO lateral support to the mast. Its why the process has risk. Once the mast is in the crutch, it is safe as long as the crutch is well braced.
I personally would build a very secure crutch that would hold the mast at the desired clearance. The trick is having a easy and reliable way to get it from vertical to the crutch, and back.
Jun 2, 2004
3,672
The Diagram will Not Apply
The mast is about 30' long and will be about 5' above the water line where it starts to swing back at the mast step.
I believe that just laying the mast back into the crutch from the hinged mast step will get you under a 16' bridge.
The 23.5 has an extra set of shrouds just for raising and lowering the mast so there is no issue there. Get the manual and make sure you have all of the parts for the mast raising system and know how it works.
Jun 2, 2004
3,672
The other issue with the Diagram
The 90 degree angle is on the wrong side. You want to measure 16' straight up to the end of the mast not 16' 90 degrees out from the mast that measurement is useless. Not that it is significantly different just not the correct angle for what you are trying to figure out.
Nov 19, 2013
34
Hunter 23.5 Tampa
Olas
Best advice thank you!!!
Nov 8, 2010
11,386
LOL you're right. The site I used to draw that didn't like the ASA combination I used and turned it around.
May 24, 2004
7,228
CC 30 South Florida
It has been said before but let me reinforce the notion that as long as you are lowering the mast go ahead and drop it all the way into a mast crutch. You do not want any lateral movement on that mast. Any waters used by powerboats cannot be assured to be calm 100% of the time. As a word of advice that is bound to get old real quick and will seriously limit your enjoyment of the boat. Do not see the desireability of keeping a sailboat at such location.
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
... And remember... after you lower the mast to whatever angle... like when you carry a long piece of lumber on your shoulder, you have to remember where the other end is. BrianW
-na -NA Anywhere USA
Since the introduction of the 23.5 by me, I will chime in as I had many customers with low bridging.
You will need to measure the back end of the mast or top of the mast to the waterline while sitting in the crutch. That will give you a determination as to what you can do. Also, check the mast raise pole as to height if left up as it might be higher than the back end of the mast.
Some folks have in the past tried to lower the mast further putting it off the the side of the mast crutch putting strain on the mast step and mast retaining pin which could damage that. The thought of heeling that boat over with a water bottle or water bag is nuts as you will loose rudder control. Therefore, if the top of the mast cannot clear the low bridge with it sitting in the mast crutch, forget it unless you want to take the mast pin out of the mast step thus disconnecting the mast from the mast step altogether.
Jun 2, 2004
3,672
Good Tip on the Gin Pole Dave
I did not think of that and I can see with all the focus on the top of the mast how that could be missed and do some serious damage.
Counting Stars;
if you have seen my posts, the 23.5 was my child from the get go. Therefore I will speak from experience and knowledge.
With the mast down on the mast crutch, you will need to measure the top of the mast to the water line. If it clears that bridge height but it is close, make sure no boats are coming thru while you are going thru or the wake will cause the mast to hit the bridge if too close. You can always detach the mast from the mast step but in no circumstances try to lean the mast to any side or you will break seals, cause damage to the mast step and bottom of mast and so on.
Forget the crap about heeling plus you will loose steerage. I speak from experience on this as I have put boats in many places with low bridging. Just look and if possible, then try but forget going the extreme.
crazy dave condon
Nov 19, 2013
34
Hunter 23.5 Tampa
Just wanted to thank everyone for all the input... Just an update! I moved the boat into Channel-side downtown Tampa yesterday...the lowering of the mast was simple... My fiancé controlled line while I guided into the crutch... Went backwards to the bridge could tell there was plenty of clearance on 16 ft maybe 5 ft left to play with... Noticed the pole to assist that was sticking up higher then the mast in the crutch...
You will find this to be a great forum for information on your boat and do not forget the information on your boat to be found under boat information above.
