The keel bolt nuts in our O'Day 322 are very deep in the bilge well. We found the forward three larger bolts to be 1" course-thread bolts (determined by a measured 1-1/2" nut flat-to-flat). We're having a difficult time confirming the size of the one smaller aft course-thread bolt. Looks to be ~ 1-1/8" nut flat-to-flat, therefore a 3/4" bolt. The bolt thread protrudes a good bit, making us think a standard deep-well socket won't be deep enough, and that we'll have to use an extra-deep-socket. Anyone have any feedback on those specifics?Yes, use a half inch drive torque wrench to torque with an extension. Anything specific just ask.
The torque specifications for the O'Day 322 are as follows: 280 Ft. Lbs. on the 1" bolts, 160 Ft. Lbs on the 3/4" bolts.The keel bolt nuts in our O'Day 322 are very deep in the bilge well. We found the forward three larger bolts to be 1" course-thread bolts (determined by a measured 1-1/2" nut flat-to-flat). We're having a difficult time confirming the size of the one smaller aft course-thread bolt. Looks to be ~ 1-1/8" nut flat-to-flat, therefore a 3/4" bolt. The bolt thread protrudes a good bit, making us think a standard deep-well socket won't be deep enough, and that we'll have to use an extra-deep-socket. Anyone have any feedback on those specifics?
Thanks everyone,
E & N
Thanks for the info. Did you find that the torques were off when your tried to tighten them and or were they pretty much good to go??The torque specifications for the O'Day 322 are as follows: 280 Ft. Lbs. on the 1" bolts, 160 Ft. Lbs on the 3/4" bolts.
That is from my Manual from the last page in the commissioning section.
I bought the deep impact 3/4 drive sockets along with a 1/2 to 3/4 adapter from northern tools after searching everywhere for them with no luck.
My keel to boat joint is covered by a thin fiberglass layer to smooth out the gap and it looks very smooth and you can not see the seem.
They were in need of tightening, but I've only torqued them one time in the 3 years I've had the boat. I was just a little worried that tightening them to often might lead to compressing the fiberglass and cause more issues.Thanks for the info. Did you find that the torques were off when your tried to tighten them and or were they pretty much good to go??
Yikes - I think you'll find 280 or 160 ft-Lbs almost impossible to acheive with a 1/2 drive torque wrench, sliding around on your cabin sole to get leverage. Just for perspective my keel bolts uses 1-1/4" socket and my manual states 140 ft-Lbs.The torque specifications for the O'Day 322 are as follows: 280 Ft. Lbs. on the 1" bolts, 160 Ft. Lbs on the 3/4" bolts.
The studs in our boats are 3/4 inch. I think Dave Mauney sent me the torque values once but I don't know where I stored them. You might send him a PM to see if he responds. They should be torqued while the boat is on the hard so you aren't lifting the weight of the keel with the torque of the bolts. That load will increase the friction force and lower the clamping force on the joint. With thousands of pounds of clamping force on each bolt there should not be any change in the position of the keel relative to the hull whether in the sling, in the water, or on the hard. That joint should be completely solid with no motion whatsoever. The torque on the bolts stretches the bolts so it is like having a massive spring clamping the joint together. This link shows for 316 stainless 3/4 inch bolts 131 foot pounds. That should do the trick. Other sites provide clamping force for torque and bolt size. This torque will provide over 8000 pounds of clamping force ON EACH BOLT. Since you have seven or eight bolts this should provide well over 50,000 pounds of force to hold up a 4500 pound keel. Hope this helps. http://www.engineershandbook.com/Tables/torque3.htmJibes, do you know what the torque would be for our boats? Would it make a difference if you were tightening the keel bolts while the boat was blocked up with the keel supported as opposed to the keel hanging when the boat is in the water? I've often wondered if the space between the boat and the keel is different when the boat is suspended on the lift. The paint seems to wear off at the keel joint both at the front and back each year but I'm not sure if that is enough of an indicator of a problem. Could be just paint adhesion to the caulk.
