replacing gasket on vacu-flush toilet
103
- - San Diego
One of my two vacu-flush heads on my 2000 Hunter 420 no longer holds water in the bowl after flushing...disappears in less than an hour. I suspect a worn-out/leaker gasket on the curved flapper.
I need advice on how to replace it...can I do it myself? does it need professional help?
All help appreciated.
Nov 9, 2004
110
Hunter Passage 420 Rock Hall, MD
Easy to do. Just get the part and follow the directions that come in the packet.
Sep 27, 2011
29
HUNTER PASSAGE 456 TX
Note the chooker
Pretty sure it's the bowel seal, the white ball that opens to flush is seated in a two part rubber donut. It gets a calcium deposit on the edge gets brittle, that needs to be replaced
