Dear Sailors,
I have a 1989 Hunter 30. I tried to remove the port cleat on the traveler. It was tight so I used my drill which has a hammer switch. Needless to say that screw snapped quickly with little applied pressure.
I do need to remove that cleat because under it is the bolt/screw that I need to gain access to in order to tighten the traveler down to the deck.
There are spaces in the ceiling, port and starboard, where the screws holding the traveler in place protrude. Access to these spaces is gained easily. In both spaces, there are three screws that protrude and, in my case, the nut for one of those screws is loose and drips steadily when it rains-both port and starboard.
Do any of you have experience with this problem or one like it?
The problems identified here are:
1. Broken screws -- I am almost certain that a screw removal tool will be a colossal exercise in frustration and futility???
2. Leaks into the boat because the traveler "bolts" are not tightened properly
If you have any suggestions, I would appreciate hearing about it.
Thank you
Steve
Thank you
Steve
