C 30 traveller problem
49
Catalina 30Mk III Oyster Bay
I have a 1992 Cat 30 with the flat traveller. The leads to the cockpit pass thru a bullseye on the coach roof and provides a bum (lousy) lead to the line stopper. This makes moving the traveller under load even more difficult.
I would like to install a block in place of the bullseye but don't know what's underneath the fairlead, line stoppers etc on the coachroof near but not on the winch pads. None of the line handling equipment is thru-bolted to the interior so there must be something solid in there (wood, metal??).
Any suggestions or knowledge of what's in there appreciated. Anyone else worked on this problem?
LuzSD
Feb 21, 2009
1,009
Catalina 30 San Diego/ Dana Point, Ca.
gosh I just spent about 5 minutes just trying to visualize what you were describing. I wasn't very successful. Can you take a picture, that would make it really easy:)
mortyd
Dec 11, 2004
952
Catalina 30 easy living
i have a 91 and probably had the same set up have you do when my boat came from the factory. i also had the same frustation you do. then i replaced the factroy traveler with one from garhauer and it's now a pleasure to use. it wasn't all that expensive.
jrowan
Mar 5, 2011
1,294
If the linestopper or fairleads are not through bolted, then what makes you think that
there's something else where they are drilled & screwed down into the cabin top, other then the fiberglass sandwiching the balsa wood core? Catalina and your P.O.'s routinely drilled holes & installed items on deck without through bolting smaller screws & without filling around the holes with epoxy, etc. Sailors & builders in the 70's & 80's just weren't as conscious or conscientious about preventing core rot & damage back then as they are today. We see the results of what wasn't done properly 25 years later, unfortunately.
52
Catalina 30 MkII Forked River, NJ
I replaced the single starboard sheet stopper with a triple on my 94 C30. When I tried to anchor the additional screws from the triple stopper into the fiberglass of the coach roof I broke the first screw off. I went back and looked at the screws which had attached the single stopper and realized that they were not screws but bolts. There is a brass plate about 1/8" thick under the fiberglass under the original single stopper. I drilled and tapped the remainder of the holes into the plate successfully. I don't know how much of the remainder of the coach roof has brass plate under the fiberglass but it makes sense that a highly loaded device like a sheet stopper wouldn't be anchored solely to the fiberglass deck. If you drill into the fiberglass and it suddenly gets hard to drill there is probably a plate there.
Jul 8, 2011
49
thanks drazlou - does your traveller line pass thru a bullseye or the triple rope clutch? I found the bullseye for my traveller line passes thru an plastic (no metal insert) bullseye and is abraiding away the inside diameter of the bullseye. Did you manage to get a fair (good) lead angle to the ropeclutch for the traveller? Mine has a lousy steep angle and makes jibing tough for a singlehander. Will plan on tapping for new hardware
mortyd
Dec 11, 2004
952
my boat is at consilidated on city island for the winter - not that far from oyster bay. you are welcome to take a look at my working installation. it seems catalina 30's have gotten all kinds of rigging once they left the factory. one thing for sure, the factory traveler is below mediocre. if you mean a bullseye (?) through a doger window, i had mine change to vertical slits which have made a world of difference. remember, you can't undrill holes.
Jul 8, 2011
49
mortyd - I'm at Stuyvesant YC across the road. Can I ask Wes or Chrysta if I can take a look at your boat?
Aug 8, 2009
52
obsailor, I asked the same question about taking the traveller lines to the winches when I got my C30. Whenever I used the winch the line would override because of the angle and jam. Many people on this forum told me not to use the winch, it's not that hard to pull the traveller line by hand. Whiile I may argue about it not being hard to pull the line it's definitely better not to use the winch. My traveller has cam cleats on the aft end of the traveller which requires you to pull the line up to unlock the cam cleat whenever you use the traveller. Since the cleat is three feet in front of you and the line passes though a hole in the dodger window it's a real PITA to use. Stu Jackson posted a picture of his arrangement which relocates the cam cleats to the back of the coach roof where you can easily lock and unlock the line. I am going to move mine to his location and probably upgrade to the 6:1 traveller upgrade sold by Garhauer rather than fight with the standard 4:1. Maybe Stu can tell us if he found a brass plate under the fiberglass to anchor his cam cleats to although he has a C34 which may be different.
Lou, the back edge of the cabintop has no metal plate. Anyone can find out if there's a metal plate by using a light hammer and tapping around - you'll hear the difference in sound. Also, if something is connected to the cabintop and it doesn't have bolts and nuts underneath, that's most likely the location of a plate. WADR to jrowan, our experience has been different - bedding properly is another issue! :)
Another consideration, also discussed every time this issue arises: the bolts (or screws) for a sheetstopper and a cam cleat are in SHEAR, they aren't going to be pulled UP because the load is perpendicular to the bolts.
Drill the holes, epoxy them if you must, bed 'em with butyl and be done.
As Lou explained, when we upgraded our traveler to the 6:1, instead of needing the slit in the dodger front window, we only needed a grommet in the new dodger front window. The turning block replaced the cam cleat on the traveler cars.
If you can't envision this, let me know and I'll find links to pictures.
Good luck.
Jul 8, 2011
49
Lou, I have a camcleat located well aft on the cabin top with a bullseye fairlead foward of the camcleat and slits in the dodger. I'm replacing the original bullseye which had no metal insert (severely abraided) with one that has the metal insert. Even then the lead angle from the traveller to the bullseye is steep. Which Garhauer model are you switching to? Next discussion question will be about how to improve mainsheet handling. thanks
Aug 8, 2009
52
obsailor, I emailed Garhauer and described what knid of traveler my boat has and the upgrade I was interested in and they emailed back "call (909)985-9993 and speak with Guido" so that is what I'm going to do. I know what it looks like from the Garhauer site and from a C34 next to me so that's where I'll start. Stu says they are good to work with and will make modifications to match what you need so I'll give it a try. This year I really tried to use the traveler and found it to be very effective but the standard traveler is a back breaker to use.
Jul 8, 2011
49
Lou, thanks for the information - I will call Garhauer and get the upgraded traveller equipment. Let's compare notes next spring!
