Winter Cover Frame
276
Catalina 310 Toronto, Ontario
Another Puzzler!!!
I have a winter cover made by Genco for my 310. Unfortunately there was no frame with it.
The owner said it was a wood frame but others said it should be an aluminum frame. Does anyone happen to what it should be and or have a frame plan that I can produce my own from.
CHEERS
Irish Rogue
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
Lost Parent: Look close and detect the strapping method used, plus, it probably has crutch feet on each foot. Chief
1,096
CS 30 Toronto
Wind the pipe conduit how do you attach it to the stantions
Does not attach to the stenchion. Has PVC chair feet to protect the deck. Actually the picture shows the stenchions were removed to prevent bending by the wind. The strapping keep the frame in place. Its quite rigid once everything is tensioned down.
Since the pic was taken I have made it a bit wider by 6 inches. No need to remove the stenchion now.
It only take 2 hours to put up the frame and cover.
I put everything on the deck before the crane haul the boat out. No lifting of heavy pipes and tarp up to the boat on cradle.
