Do I need a pedestal guard?
156
Hunter H33C Quincy, MA
is there a reason, other than mounting instruments or a teak holder of some sort, to install a pedestal guard? this is an expensive project, searching for used options lead me to believe that I can do almost as well with new through one of the online retailers. . . does anyone make a bracket that mounts on the pedestal for mounting an instrument (or two)?
Nobody "needs" pedestal guards or, sailboats for that matter. I loved my $1100 Edison with single lever shifter and $300 nav pod. Found out later that Navionics software on my IPad was best nav tool I have ever had.
Dec 14, 2011
316
Navicula 430 Hunter Toronto
a grab rail....is a great asset ... A must have to get around the cockpit
Ross
Jun 15, 2004
14,693
You can grab the pedestal guard or the engine control. Your boat , your call.
arf145
Nov 4, 2010
495
Beneteau 331 Deale, MD
I added a pedestal guard to the Edson pedestal on my last boat purely so I would have a place to mount a chartplotter. But we soon were marveling at how we ever got along without that wonderful handhold!
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
Very handy to have a pedestal guard. You can often find them on eBay or in consignment stores for a good price. Get one. You will like it.
Johnb
Hunter 37-cutter Richmond CA
Maybe quite simple
A pedestal guard could consist of just an upside down U which might be made from a 10 ft piece of SS tube attacked with a pipe bender. The pedestal provides the support, or am I missing something.
156
thanks for all the replies. . .
Warren - I did look around on eBay, it didn't save that much going eBay "new" vs. some online retailers. . .
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
I have just a simple pedestal guard you can have for free. It is fir an Edson with the normal 9" spread.
Dec 25, 2008
90
Catalina 34 St. Simons Island
I recently installed a Lowrance HDS7 Chartplotter at my helm and faced the problem of whether to add a pedestal guard or not. I decided against it primarily to save room in the cockpit and to avoid drilling holes in the cockpit floor. I did have to construct a custom made mounting system but came up with a design that gave me a nice drink tray as well as base for mounting the chartplotter.
Click here for a link to a picture.
Nov 24, 2012
586
The one thing you'll have to remember about it is that it's going to be grabbed by you or the crew in the worst of sailing conditions and with full force. So make sure it's sturdy.
Oct 17, 2011
2,809
Ericson 29 Southport..
It's really more like either/or. With Edsons' ped bracket holding the guard at roughly 6 inches from the X & Y, (kind of), and the guard bolted firmly down makes an incredibly strong handhold, as you've increased the footprint exponentially. With a good cockpit floor, on my boat I think I could tow with it. Not that anyone would do that, but it would take a helluva lot of yanking on it by a tough man to do it any harm..
Ross
Jun 15, 2004
14,693
Remember that when the going gets tough, the tough grab hold of the closest thing and hang on.
11,704
The NavPod SG-10 is a reasonably priced 1" straight pedestal guard for an Edson pedestal. You will then need a pedestal guard top plate Edson #1625ST-45 and they run about $100.00. Lastly you will need Edson pedestal guard feet Edson #310ST-100-125 and they run about $60.00.
For mounting electronics I created/designed the method below and also manufacture and sell the mounting boards pre-made to make it easier.. It will fit 4" 5" and 7" plotters.
Feb 14, 2010
156
thanks for all the input, and a Big thanks to Bob M for the pedestal guard - have to get the feet and bracket and install. . .
question to all - I've noticed in pics of setups that chartplotters seem to be close to the compass - is there a minimum distance that needs to be maintained between the instrument and compass? Standard Horizon tech support told me "several feet", but that doesn't seem to be the case with what I've seen. . .
11,704
All electronics can interfere with the compass. It is always best to have a competent compass adjuster come to your boat, swing the compass with the electronics on and off, and make you the deviation cards.
With my mount above the unit can easily be removed and your compass is no longer affected, provided you have a deviation card for that scenario as well.
In this day and age it seems no one cares about compasses, not Garmin, not Raymarine no one, not even boat owners or boat builders. I just came back from the Annapolis show and 7 figure boats have 12" plus plotters mounted 6" from a magnetic compass.....
That said its not just builders most boat owners could care less too. I can't tell you the last time I was on a boat that actually had a deviation card, including the one that left for the Bahama's last week....
I still prefer to have a well calibrated professionally swung compass and my electronics at the helm. Most of them can be swung and deviation cards made even with electronics close by....
