Bilge in Head for Shower
35
Catalina 30 Everett, WA
We are thinking of cutting a space in the floor/deck/sole of the head for a drain area and adding a bilge pump there to keep the water from draining against the compression block in the main bilge. Is there enough room under the floor? I would hate to find out while cutting that I have just made a new thru hull to Puget Sound. :eek:
Jul 8, 2011
704
Catalina 30 Sidney B.C.
Dont do it
I removed the existing drain grate and ran a 1/2 in line through the existing black rubber tube and down into the bilge and to the rear of the bilge and then up to port where i installed a surflo utility 12 volt pump and then up and out the side through a side through hull above the water line , installed a switch for the pump up on the bathroom wall works super sealed the drain in the shower with sikaflex has been going strong for two years
May 10, 2004
207
Beneteau 36 CC Sidney, BC, Canada
I agree with windcat. Use what is there don't mess with the head pan there is no room to work with under it. Personally I installed a shower fitting in the port cockpit coaming and plumbed it to the pressure water , it is comfortable sitting on the cockpit sole having a shower and there is no moisture (and resulting mildew etc) from the head shower which in 15 years on our cat 30 we never used.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
Dont do it
You should have a vented loop in that line.
