...bottom paint???
NorSea 27 Az., Doing the To-Do list
WOW, :eek: Impressive stuff.
I wonder how it holds up. Does it wear off with time or contact? How about in sunlight (like at the water line)?
Can't say I would use it on my clothing, but for a boat, even a dink might be very positive! Cost per coverage area?
Jul 8, 2012
144
Helms 25 indiana
all I can say is wow! if that could be used on my boat at or below the water line.... interesting. makes you wonder. might have to check this out for myself...
What about biminis, dodgers and foul weather clothing, bilge. Seems like if this stuff is UV resistant, it would find uses just about everywhere on a boat.
I'm going to keep my eyes open for this stuff.
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
If any of these products had any use in an anti fouling application, you can bet the manufacturers would advertise it as such. But they don't.
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
Here is the link to Rutsoleum's faq which provides some preliminary answers to some questions posed about UV and durability.
http://www.rustoleum.com/homeowner/faqs/neverwet-faqs/
Fiberglass is supposed to be one of the surfaces it can be used on. However I wonder if it is compatible with bottom paints. Some posts on the forum have been touting the usefulness of Rustoleum as a bottom paint. I suppose the downside is that it has no biocidal qualities. Perhaps in combination with Neverwet could be a winning solution.
Feb 26, 2011
1,440
11. Can Rust-Oleum NeverWet be used on surfaces that are continuously submerged?
Rust-Oleum NeverWet relies on a layer of air to form the superhydrophobic coating on the surface of the object. For this reason the product is not recommended for surfaces continuously submerged in water or liquid.
I am one of those who use Rustoleum on the bottom of my boat... BUT I am a trailer sailor and don't keep my boat in the water for extended periods of time. So I don't need biocides in my bottom paint. I doubt it is a good choice for everyone.
I think every decision has a trade-off. I didn't like getting the chalky stuff on my skin every time I bumped into the bottom of my boat (especially swimming) and I didn't see a need for it anyway. I guess that if I ever decide to keep my boat in a slip, I'll need to reconsider the bottom paint issue.
Aug 16, 2009
1,000
Well, fst found the answer that puts this product to rest.
Jun 1, 2004
8,348
heh, heh, you'll save some money and time if you pause to read the label first. Teaches you to go to the source if you have a question. Anyway, until that revelation I was going to put some on the bottom of my shoes so I could walk on water!
Aug 16, 2009
1,000
Although the video touts the product for fabric, the review said that it made fabric kind of stiff and not necessarily 100% waterproof. So I wonder to what extent it stiffens fabric and whether it is a good product for sail/winch/rail covers or dodgers and biminis? What about the plastic window on the dodger?
Also what about using it as a sort of sealer [not a replacement for but in addition to bedding or caulking] in places not subject to abrasion, such as around ports?
Jul 18, 2009
274
marine clipper 21 ft santa ana Southern Lakes,Yukon
This stuff has been tried on snowmobiles under the tunnels and on running boards etc to lessen ice build up.
iTS BEEN APPLIED IN IDEAL CONDITIONS AND AS PER DIRECTIONS...and it does not last..
As a matter of fact if you research what the manufacturer claims its made for and read reviews it hardly meets satisfaction from users for what it is intended..
