ok, you probably thought I was meaning the kind you drink... but no, I'm looking for cheap sources for stove fuel. The Kleen Strip denatured alcohol that is readily available burns dirty and leaves a sooty residue on the pots as well as on the burner itself.
The Origo fuel burns clean, but it's harder to find and much more expensive.
I did a little searching online and came across this, http://www.woodlanddirect.com/Firep...ies/Eco-Feu-Liquid-Ethanol-Fuel-Gallon-4-Pack which is really cheap at $20/gal, and claims to be clean burning.
Which fuel does everyone use in their stoves, does it burn clean, and has anyone tried this Eco Fuel I found?
