O'Day 25 bracket replacement
55
oday 25 lake conroe
I need to replace the bracket whose springs are sprung on my boat which is powered by a 9.9 H.P. 2-stroke Johnson.
The bracket is attached with what looks to be long lag bolts going thru the housing attached to the stern of the boat.
How do I get access to the nuts on the bolts and How can I ensure that the new bracket will fit the existng housing bolt holes?
Will I need to do any modifications if I get a new 9.9 H.P. 4-stroke?
Erieau
Apr 3, 2009
209
Oday 25 Erieau
If the bracket is attached with lag bolts, there will be no nuts. Simply spin them out.
It it is attached with machine bolts, the nuts are on the inside of the transom, so have a skinny friend squeeze down into the cockpit locker and hold them with a wrench while you socket-wrench the bolts off from the outside.
The "housing" that the bracket is bolted to is just a block of fibreglass. If it's stuck to the transom with adhesive, just back-fill the old holes with thickened epoxy in a syringe, and re-drill new holes for your new motor bracket.
May 31, 2004
858
Catalina 28 Branford
On my Oday 23, the mount is attached with machine bolts that are readily accessable through the big cockpit locker. When I replaced the outboard bracket, I also replaced the bolts. I also had to repair the big block of fiberglass that is between the bracket and the transom. Water had gotten inside and rotted away the wood core. I scraped out the rotten wood and put unthickened epoxy inside to firm up what was left. I added a few sheets of new glass cloth wetted out with epoxy on top. I redrilled the holes and was good to go.
I picked my replacement bracket so that the existing holes on the block and through the transom could be reused. The Garelick two stroke mount sold now should accommodate the original Oday hole pattern. However, if you are thinking of updating your outboard to a four stroke, you may need to do more work. The four stroke motor mounts have a broader base and will not likely fit onto the existing block (which will be too narrow). This means you would have to make an adapter for the existing block (maybe a stainless or fiberglass plate), or make a new block. I've seen them made from plywood or Starboard.
Is it necessary to have a motor mount that is specifically rated for four strokes, or can a robust two stroke mount deal with a four stroke engine? You will find many threads on this and other sites discussing the issue. Some say that so long as the mount is rated to handle the weight of the engine, it doesn't matter if its a two stroke or four stroke; others have said that a four stroke creates so much more torque that the two stroke mounts can't handle it. I'm not an engineer and don't play one on TV, so I will keep my opinion to myself. Do your research and make your own determination.
Ward H
Nov 7, 2011
3,814
The bracket on my 25 is bolted flat to the transom with a 3/8 or so thick spacer. The spacer looks like a sheet of nylon. Doesn't look like starboard but could be. I always wondered if there was a "hump" that was cut off and covered by the spacer. The bracket is bolted through the transom and is backed by epoxied plywood on the inside.
I saw another 25 done this way in the marina and it had the same type hydraulic assist lift on it so I guessed maybe they were installed by the same yard.
The hydraulic assist lift bracket is nice. Not sure what name the bracket is.
I would call Garelick about what mount to use. When looking for a mount for my 4 Stroke 4HP OB to put on my 17' boat, they advised a certain 2 stroke mount which would carry the weight.
59
Oday 19 Lake George
I had a very similar question about access to the inside of hull to remove/replace the motor mount. I have an ODay 19 with machine bolts and no way to reach inside nuts. The access hole thru center of transom from cockpit is too far away and the aft end of starboard locker is solid flotation attached to all sides. I even considered putting in another thru hull access point but feel it would look very strange and perhaps weaken structure. Any thoughts? Thank you, Bill
Ward H
Nov 7, 2011
3,814
AWalker, Thanks for identifying my bracket. Never heard of OMC. Works well.
