Ok, so from my small dinghy days, I learned that with boats equipped with a powerful vang, or kicker (upwards of 8:1 or 16:1), you can pull on vang to depower the sail. My understanding is it will bend the mast, curving it forward, which the sail is cut with a forward curve to the luff, thus allowing the sail to fill out its natural shape and have less camber. (Pulling the curved luff straight is what induces camber.)
But then, on a bigger boat, with not necessarily a bendy mast, pulling on vang will tighten the leech, and remove twist from the sail. But allowing the top of the sail to twist off depowers it. So, on a bigger boat, if on point of sail other than reach or run, pulling on vang WON'T depower the sail.
Am I understanding this correctly? If so, it seems that to depower a bigger, fractional rig boat with an adjustable backstay one would want to pull on backstay to get the same mast bend that smaller dinghies achieve with vang, while still allowing the sail to twist off with little to no vang.
Thanks - yeah, I guess I should just pony up for Don's book...
Brian
Brian
