Refrigeration (not A/C) Pump Woes
It seems when we're beating on a port tack the refer s/w cooling pump comes above the waterline and, being a centrifugal pump, it stops pumping.
There is no way to put it lower in the bilge so I am seeking another solution. Could an impeller pump be added in parallel to the centrifugal pump so that underway it could turned on to constantly prime the centrifugal pump? The centrifugal pump does not have the power to pass water through an impeller pump so they cannot be inline. I'm thinking that the system would be pretty much automatic; when not in use, the impeller pump would not affect the operation of the centrifugal pump and no valves should be needed.
We run this pump about 1200 hours a year. No impeller pump I can afford will do this job, so we must primarily use a centrifugal pump.
Any thoughts would be appreciated.
