I bought an abused 1980 O'Day 19 last fall, and finally got her in the water this summer. Like most FG boats she was structurally sound, just needed some TLC and a new main. What a great sailing boat! Incredibly stable for only 1400 lbs. Huge cockpit, lots of room for 4 - 6.
Anyhow - my last sail of the season (Leaving the boat in MN for the year.) the line that pulls the CB up, stripped. It actually didn't quite break, but the outer cover of the line stripped off, leaving only the core. The CB isn't very heavy - 150lbs I think. I was able to inspect it in the water and could see that the line was glassed into the CB, not drilled through and attached with a fitting. So I can't just cut the line and attach a new one at the same point. I do not have easy access to lift the boat and drop the CB to get the attachment point. And re-doing it the way it is would be a pain. The old line would have to be cut out of the CB, and a new line glassed in.
So, the question is - does anyone know how wide the CB trunk is at the TOP of the trunk. And how wide is the CB? How much room on either side is there? It's about 1 3/4" at the bottom, but I couldn't really see how far it narrowed. Or if there is any room to drill a hole in the top and attach some kind of fitting to run a new line, which could be done in the water with a hand drill and a long snorkel. Or even just a bowline.
There are virtually no sailboat services where the boat is in MN. (Near Detroit Lakes.) And I only paid $500 for it, and will only use it 2 weeks a year, so I don't want to spend a pile of money fixing it.
Any help or insight would be most appreciated!
