Deciding to go Solar, I observed that the best buys in Solar Panels per watt are those in the 200-250w range, since they are the produced in the highest volume mainly for the housing market. Unfortunately they have high shipping cost due to their size. (68"x38") especially if you buy only one.
I decided that I did not want to mount the panel over the dinghy davits but wanted to mount it over the bimini, aft of the bimini window used for viewing the mainsail tell-tales, the Hunter 33 arch provides two convenient places to mount a deck hinge. Using 5 foot lengths of 1' SS tube and standard tubing fittings I was able to construct a mounting frame and only having to cut two pieces of tubing. Using 5 ft lengths saved money over the 6 ft lengths commonly sold.
I could have mounted the U-Bolts directly to the Solar Panel Frame, but it would have been awkward tightening the bolts from underneath the panel. Instead I decided to bolt two aluminum angle bars to the sides of the Panel Frame and flush with the bottom, This allowed for easy acess for tightning the U-Bolts from above. The Solar Panel can be easily removed, by removing the 4 U-Bolts, and disconnecting the wires. Likewise removing 4 screws allows for removal of the support frame.
I used 10/2 AWG Marine Duplex wire to connect from the TYCO Connector pigtails (extended 2 feet, Oops!) I ran the wire into the arch and down to an aft cabin starboard access panel and then forward to the MPPT controller mounted just above the AC & DC Panels. From the MPPT I used 6/2 AWG Marine Duplex to the DC Ground Buss and the battery selector switch. The Positive out, first goes to a 25a fuse in a Marine Grade Electrical Inline Fuse Holder (ATC, 12-Gauge).
I finished the project just in time for a one week cruise, where it performed up to expectations, bringing the batteries up to 100% everyday. The biggest
continuous draw on my boat is the fridge at 3.9a, and due to the unusual hot weather seemed to be always on. The next biggest draw on the cruise was our thermo-electric "beverage" cooler at 5a, that we only ran during the day. Since we got back I have not run the battery charger and have relied on the solar to keep the battery up, the fridge is of course still on. I have not done a total check on power output but did see 160watts to the batteries at 2PM one day. The controller will limit output power to 200w, but with a non-tilting panel I doubt I will ever be controller limited. I also plan on running Morningstar's datalogging software "MSView" on my laptop, as soon as I get an adapter.
As you can see from the side view photo there is a slight tilt forward to the panel, I plan to put blocks under the deck hinges on the arch to elevate the front of the support frame enough to get a slight tilt aft.
Cost of SS Support Frame was $279
Cost of 235w Solar Panel & Shipping $268
Cost of MPPT Controller $199
Cost of Wire $37
Total Cost $783 or $3.33/watt
Solar Panel
1 x MX Solar 235W 24V Solar Panel MX60-235 = $165.00
Federal Express (40lbs) (Home Delivery (5 days)): $103.38
Total: $268.38
Morningstar Sunsaver MPPT 12/24V 15A Charge Controller ( 140803890002 )
Total $199.99
Solar Panel to MPPT Controller Wire
Genuinedealz.com Item #13345644
10/2 AWG Marine Duplex - Flat Blk/Red 25 FT (Oops needed 27 ft!)
Price: $26.45
MPPT Controller to Battery Switch Wire
Genuinedealz.com Item #13353494
6/2 AWG Marine Duplex - Flat Red/Yel PER FT
Price: $2.80
Quantity: 5.00
Total: $10.40
Stainless Fittings
QTY.ITEM NO. PRODUCT PRICE EXT. $
2 88287 Stainless Rail Fitting - 90 Universal T | 1" - each $7.15 $14.30
2 88320 Straight deck hinge | With a Panhead Bolt - each $3.35 $ 6.70
2 88366 Split Rail Fittings | 1" rail - each $9.25 $18.50
4 88397 Stainless Outside Eye End | 1" - each $4.45 $17.80
Subtotal: $57.30
Handling & Insurance: $2.00
Shipping: $12.77
TOTAL: $72.07
2 Stainless 1" 90 Elbow $12.25 each Total $24.50
Stainless Tubing
5 pieces @ $23.52/piece=$117.60
Stainless T-316/316L
Welded Tube
1" x 0.035" x 0.93"
Cut to: 60"
Shipping Cost: $20.34
Cut Fee: $0.00
Total: $137.94
4 SS U-bolts @$5 ea =$20
2 Aluminum 1"x1/8"x72"angle stock@$12 ea = $24
Cost of Wire $37
Solar Panel
Total: $268.38
Total $199.99
Price: $26.45
Price: $2.80
Quantity: 5.00
Total: $10.40
Stainless Fittings
Subtotal: $57.30
Shipping: $12.77
TOTAL: $72.07
Stainless Tubing
Welded Tube
1" x 0.035" x 0.93"
Cut to: 60"
Cut Fee: $0.00
Total: $137.94
