Bottom paint ??
5
hunter 23 Petenwell
I recently purchased a Hunter 23 that I plan to sail in fresh water . There are so many bottom / antifouling paints to choose from how do I know which one is best for my use. The boat is trailer able but I do plan to keep it in the water for entire seasons.
Dec 2, 1999
15,184
Pettit Trinidad SR is one of the better all around paints.
Check with sailors in your area for other ideas.
Hunter 29.5 Gloucester, VA
Agree with Steve, ask around marina's there and see what others have had success with
Sep 27, 2008
24
Hunter 23 Massabesic
I keep my Hunter 23 on a lake in NH. It has never been bottom painted. What I do is put her on the trailer in mid Aug pull her up on the ramp and pressure spray the bottom and then back her back in the water. I have access to a water hose because I'm in a sailing club that has a hose and running water. This works for me and I save a bunch of money. If I didn't have access to running water I would scrub the hull with a soft brush.
Freebird
Jan 2, 2013
74
Hunter 23.5 Lafayette, LA
Any idea how long a boat can be kept in the water with out bottom paint. I would be worried about blisters.
Oct 6, 2007
1,164
Hunter H30 1982 Chicago IL
Need a barrier coat
I can say that a typical 6 month, May to Oct, sailing season on Lake Michigan is definitely long enough to form blisters. A barrier coat is critical if the boat stays in the water that long. InterProtect 2000 barrier coat with VC-17 seem to be the standards around here (Lake Michigan/Chicago). Multi-season ablatives too.
That said, Petenwell Lake might be different since it's a smaller inland (central Wisconsin) lake and will likely be considerably warmer, so asking the locals is the best advice on anti-fouling bottom paints. Barrier coat definitely, regardless of which anti-fouling bottom paint is selected.
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
Bottom paint does not prevent blisters. If a boat is going to get blisters, it will get them whether or not it has bottom paint.
Jan 2, 2013
74
If I were sailing in FL for two weeks on a trailer sailor I should not see any growth in that time?
Feb 26, 2011
1,440
Two weeks without bottom paint? I'd say the odds are pretty good you will have some growth.
5 days will be the upper limit. Barnacles will be small, but still challenging to remove. Pull your boat up on a beach every 3 days or so and rub the bottom with one of those 3 m scrubber pads. Dingy too if you are towing.
Jan 2, 2013
74
Thanks I went four days and I could see a scum line it looked like when ok took it out of the water.
Apr 27, 2010
1,279
Hunter 23 Lake Wallenpaupack
I keep my 23 on a fresh water lake from about mid May to about early to mid Oct. Have not used antifouling paint. There is a scum and some thin, short grassy like growth at haulout, but the yard uses a pretty hefty pressure washer and it comes pretty clean. I don't race, so I don't care about any minor performance hit.
