I use its predecessor. The screen is pretty poor but I did not buy it to use the screen. I just ran NEMA 0183 to my plotter and all targets show up there. MUCH better than trying to use the screen on the VHF... Hopefully soon they will come out with an N2K version as opposed to 0183 only...Anyone uses this Standard Horizon GX2150 vhf? Appreciate feedback on how good/bad the AIS perform? Is the smallish display good enough for the info expected?
Thanks.
The screen is really small and the ais setup, in my opinion, is not all that user friendly.Anyone uses this Standard Horizon GX2150 vhf? Appreciate feedback on how good/bad the AIS perform? Is the smallish display good enough for the info expected?
Thanks.
You must have an older version. The Ram 3 has the squelch on the volume button:I have the 2150. Pretty easy to install.
I am very unhappy with the ram mic.
The cord is extremely short and things like squelch are buried in sub menus. My icom ram mic was much nicer
Squelch is inside the vol/sq button. So press vol, press vol again to get to squelch, press up/down to adjust, then press channel select to clear. Too much junk. My icom ram mic had a dedicated squelch adj. Invariably some noise will come on that needs squelching just when I need to pay attention to the helm. Adjusting the sh ram is way to distracting. And of course I'm doing this with a way too short cord. I've been pulling and pulling on it, it is not stretching out at all.You must have an older version. The Ram 3 has the squelch on the volume button:
http://www.thegpsstore.com/Standard-CMP30-RAM-3-Microphone-P2279.aspx?gclid=CPLlkMuxzrgCFcxAMgod6m0AqA
The cord is too short, but I mounted the thru-deck unit close to the helm on the edge of the cockpit seat, so it's ok. Also, you can stretch the coils a little. With this, the length has not been an issue, but yep they should have added 6 inches or so more.
Yes it works fine. At every power up, you have to clear the 'mmsi not configured' message, which is easy.Can I use the GX2150 without configuring MMSI id? I don't have MMSI and don't intend to apply for it. I just want to id each around me to ensure I'm not in their way or risk CPA collision.
SH should make an extension. There is one for the routing to the bulkhead unit, and I think the connectors would work, but it's not intended for use between the mic cord and the bulkhead. Also it's 23 feet long.Squelch is inside the vol/sq button. So press vol, press vol again to get to squelch, press up/down to adjust, then press channel select to clear. Too much junk. My icom ram mic had a dedicated squelch adj. Invariably some noise will come on that needs squelching just when I need to pay attention to the helm. Adjusting the sh ram is way to distracting. And of course I'm doing this with a way too short cord. I've been pulling and pulling on it, it is not stretching out at all.
Are you referring the the RAM3 mic cord being short? How long is it by the way. Would it be same length as the Icom Commandmic?SH should make an extension. There is one for the routing to the bulkhead unit, and I think the connectors would work, but it's not intended for use between the mic cord and the bulkhead. Also it's 23 feet long.
A mic cord extesion seems a reasonably useful item to offer. I would buy one, and use it to enable standing at the wheel, instead of having to sit down to use the radio.
Yes, the Ram3 mic cord is too short. However, if you strategically locate the bulkhead coupling close to the helm, it should be ok. I don't know the exact measurement, but I use mine at about 3 feet from the coupling. Any more and it starts to strain. I don't know about the Icom. Maybe you could hit both mfg websites.Are you referring the the RAM3 mic cord being short? How long is it by the way. Would it be same length as the Icom Commandmic?
