hello
I installed this seasense 6 circuit into my control panel recently.... on the top is a - and + sticker above the solid bar... ( + )your positive hot wire attaches here for your poser supply from your master switch.... ( - ) the negative wire attaches here to go to the negative buss bar for common ground for all your wiring and back to the negative wire to your battery.... the individual exposed wires are for the individual circuits for what you are wiring up to what items you have installed in your boat.... here is a picture of my electronic control board/cabinet.... this picture was before I had it installed.... it now has many many wires all over it...and it is working great.... I ran all new electrical wiring through out my boat... saves a lot of headaches when trying to find shorts in already existing wires... and I am removing the old wires as I install the new wires... I am also installing all new nav lights, anchor light, steaming light, deck lights, stereo, marine radio, fridge, water pump, electric stove top, bilge pump, cabin lights, and usb/cigarette plugs for other items of need.. plus I have 2 30 watt solar panels for recharging the batteries, with a 30 amp controller... f I worked out all my math, this should keep me running smooth for a week trip, and not need shore power to recharge the batteries... unless I use everything at once...
sincerely
Jess
