Help: Removing the inside companion way teak handhold board
Looking for advice or a "how to" on removing the port side teak hand hold board.
I have a loose port outside crib board frame piece.
Loose: http://imgur.com/GAYnmLj
Removed: http://imgur.com/wkcAl2p
I wanted to secure it, I see that it should be tightened from underneath the inside piece.
Inside: http://imgur.com/nGrMcOr
http://imgur.com/NwV4Uz8
I removed all 4 screws from the inside and yet the damn thing will not pull free from the wall. I've tried prying it off with a flat blade, nothing. It seems to be stuck where the actual handle is.
There are no obvious screws from the outside holding it on.
Has anyone had this off that can lend some assistance before I end up breaking it?
Thanks
Thanks
