I am following up on the responses to my discussion topic regarding my concerns about the adequacy of the standard alternator/built-in regualtor on my Yanmar 4JH5E.
The alternator is an Hitachi LR 180-03C 80 amp, with built in regulator. I've attached an excerpt from the service manual which shows that the output at max speed is 13.5V constant. I don't quite understand this, because i was under the impression that in the bulk stage the output should be 14.6V.
My batteries--all wet cell--consists of 3 banks-
1. House Bank 2 4D s, Deka 904D. The specs from Deka show CCA@0F of 1050; and Reserve capacity of 290. Frankly i don't understand these numbers and do not know how to determine amp capacity.
2. Engine start battery--Deka Group 27
3. Bow thruster battery--Deka Group 27
The principal draw on the house bank--the bank I'm concerned about--when we are cruising is s 8 to 10 amps when the refrig and freezer are working. I assume they work about 50% of the time on most days of use. The other principal draw is the nav instruments and auto pilot, say 4 to 5 amps for 5 hours a day.
I've also learned that the voltmeter on my instrument panel doesn't really monitor the battery voltage. The voltage numbers it shows varies widely as the refrig cycles on and off.
So my question is should i upgrade my alternator and or regulator? I realize a larger alternator can put strain on the belt, so I wouldn't go above 100 amps. I don't want to make more changes than I have to.
