Best way to attach a block to a cleat
57
Hunter H33 Topeka, KS
I sometimes run a temporary line back the cockpit such as a preventer line or warping line. I let the line slide around cleats, but would like to reduce the friction by using blocks. What is the best way to connect a block to a cleat? Are there blocks designed for this purpose?
Pearson 26W Marblehead
block to cleat
im not sure I understand what you want to do. The best way would probably be with a D shackle. but I do not know what this would accomplish. If you want to run a line back to a winch and need a block for a fairlead, The block would not be attached to a cleat
Dec 2, 1999
15,184
If I understand what you are asking, you would probably need an open base cleat. Then you can purchase a block with a snap shackle.
Check out Garhauer Marine for some options.
Your next option is to add a folding pad eye, which is probably a better idea anyway.
We did something similar for our Gyb'easy. We do not have any shrouds on out boat so we needed an attachment point. One folding pad eye on each side did the job.
http://www.google.com/search?q=fold...BJqTtigKesICQBg&ved=0CF8QsAQ&biw=1192&bih=890
Sep 5, 2007
689
MacGregor 26X Rochester
I have a few short pendants made from small three-strand, with an eye splice at each end. One eye is small, and is used to attach the block, and the other is just long enough to pass through the open center of the cleat and hook over both horns.
Pendant diameter would depend on maximum loads, of course, and it works best with open-center cleats (which my last boat didn't have :cry:), but it could also be done with something as simple as a bowline to a block, and a cleat hitch at the boat. Length is adustable that way, too.
May 24, 2004
7,228
CC 30 South Florida
Yes, use a line with an eyelid splice and attach a block to it then wrap the line around the cleat like you would a dock line. Fast , effective and versatile.
Sep 5, 2007
689
Harken T2 Soft Attach blocks can be purchased with either a small loop, or a length of line attached. Might be something to look into.
I keep a handful of them in a box, some with one eyesplice, others with them on both ends, as they're useful for loads of stuff. I even use them to attach the wakeboard tow rope bridle to the deck cleats. :dance:
Jun 1, 2004
8,349
Another alternative is to invest in a snatch block... it's an opening block with a snap shackle for connector. Pricey.... but many sailors have them because they are so versatile. Garhauer and Ronstan both make affordable units.
Ross
Jun 15, 2004
14,693
There are many ways to attach a lanyard to a block for use in unusual places. Ashley's book of knots devote several pages to the subject.
I've done something similar when I run a sheet to tiller self steering... but I ran it to the hand rails. I found a large carabiner clip worked very well for this purpose. I clipped the block to the the rail using one like this
But I think you could also use a strong piece of nylon line and simply tie it.
Jun 22, 2006
57
Thanks all! I'll pick up a couple Harken T2 blocks- they look like a good solution, and without any metal, easier on the gelcoat.
