I have also posted this question on a previous thread.
My wife and I just became O'Day owners two weeks ago. We bought a 1984 222 in very good condition. Didn't take a lot of clean up and the hull polished up nicely. Only surprise was when we went to step the mast. I think we have a "rogue" configurations. The tabernacle has only one hole into which a bolt and sleeve go through the tabernacle and the mast, then tightened down. Secondly, unlike all the others I've seen, the leading edge at the foot of the mast has a radius which allows it to "clear" as you raise the mast. The mast is raised by laying it over the bow pulpit, attaching the topping lift to the boom, and the boom to the mast using it like a gin pole and using the main sheet to winch it up. BUT, because it's raised from the bow end, you cannot attach the shrouds and that felt very unstable. Short of it is that we had to recruit 4 other sailors that happened by to steady the mast as we winched it up, then once up we attached the shrouds as quickly as possible.
So, the question is, does anyone else have this mast setup? I'm thinking that one of the previous owners changed out the mast, or that O'Day made a change after mine was made.
Any thoughts? I am also going to call Rudy at D&R to see what he knows.
Thanks all.
Thanks all.
