I have an Islander 30 with a keel-stepped mast. I need to add some blocks around it to accommodate various lines (halyard, reef, etc. the usual suspects). I'd rather not mount the blocks through the deck and I'm not crazy about using the mast itself. While I found a plate (see pic) that would do the trick, unfortunately it's designed to be placed under the mast. Is anyone aware of a manufacturer who makes a ring with holes that I could mount around the outside of the mast? Or perhaps someone has another workaround?
Thanks
Nestor
Thanks
Nestor
