Install rudder in the water?
279
Hunter 1980 37c Illinois
Hi All,
Can The H37c rudder be installed into my boat while still in the water? :eek:
Has anyone done this before?
Thanks in advance!
Rick Blevens
Drifter
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
Yes a rudder can be installed in the water. The tube it runs in ends above the water line. The attached drawing of the 37's rudder installation displays how the rudder system is designed.
KD3PC
1,069
boatless rainbow Callao, VA
as long as you have the depth and gear to handle the heft and can control the rudder as it is installed, should be doable. Someone, or several someones will have to get wet.
Definitely not a one man DIY job though.
Nov 22, 2011
1,303
Ericson 26-2 San Pedro, CA
It can be done but be careful...
It can be done with the boat in the water. Dropping the rudder should not be a big problem. You may wish to tie a line looped underneath the bottom of the rudder and fastened to the stern cleats for use in controlling how fast it drops. In theory it may be positively buoyant or neutral, but this is not always the case, so having the safety line might give you an extra measure of control.
For reinstalling, make sure that the individual(s) in the water who are re-inserting the rudder guide the rudder post straight up the fiberglass rudder tube. If the stainless rudder post is only slightly inside the rudder tube and the diver(s) jerk the rudder back and forth sideways they may have sufficient leverage to do damage to the attachment between the rudder tube and the hull. That's why it's my preference to do this job on the hard, where the rudder post is easily guided straight into the tube. But if you exercise sufficient care it can be done in the water.
May 4, 2010
68
hunter 33_77-83 wilmington, NC
wow, the 37's rudder is way aft of the 33's. on my 33' it is directly under your feet as you stand at the wheel.
Sep 7, 2011
279
Thanks everyone- I always do things the hard way!
Does that rudder offer any buoyancy at all?
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
Most rudders are very buoyant. However, before your diver removes it, he should check to see whether or not it's gonna wanna go straight to the bottom and have adequate line available to secure it if it is negatively buoyant.
It is often the case that larger buoyant rudders must be ballasted so that they are manageable underwater during the reinstallation. I sling a bucket of dive weights under the rudder and fashion a rope harness to keep the rudder vertical in these instances.
Jun 2, 2004
5,802
The top of the rudderstock should have a pin where the emergency tiller engages. Drop a weighted line down the rudder tube and then tie to that pin. Then you can also pull straight up from inside the boat. My old rudder would sink like a rock. The rebuilt rudder will float and be difficult to get under the boat.
Blaise
Hunter 37-cutter Bradenton
I removed and re-installed the rudder on Midnight Sun when I was a LOT younger. I remember having to weigh it down with two anchors, chain, and a divers weight belt. Even with that I had to stand inverted underwater with my feet on the hull. Even with all that I think it was easier than digging a hole for the rudder to be dropped into while the boat is on the hard. The only other way is to find a very friendly yard that won't mind hanging your boat in the travel lift for an afternoon. When my rudder was replaced a couple of years ago after the container incident, The yard did just that. It was still disconcerting to see the boat that high in the air. Ed, I don't have a pin in my rudder stock, just a piece of flat plate welded vertically that fit the notch in the emergency tiller.
