in preparation for launch day I put the motor (72 merc 7.5) through its paces, well, no tell tale. Pull the impeller, it looks fine, passageways all clear, seems like exhaust gas coming from the tell tale, may be steam. If I force water up the water tube (as though it were being pumped) I got nothing flowing through the engine...either a blocked passage in the powerhead or a blown gasket or a cracked block, or some other weird problem.
I have a yamaha 2hp that I can use but I don't think the shaft is long enough, it's an inch shorter than mine, and it was just ok. also not sure the 2 has enougn\h power to handle a 10kt wind and chop.
I can't go sailing because neither of my two outboards work. bummer.
