Opening port, GrayFixed port or opening port?
I posted an article on my removal and replacement of fixed ports in the Modifications section.
Indeed they are Gray ports. Cockpit facing are # 414 the others are 512. Stu has a good point not to pry and perhaps the Beckson tool might work. I used an long exacto blade to cut through the dried-up caulking. Worked OK but long and tedious if you want to make sure not to damage the gelcoat both inside and outside. The store here can get the Gray and the Beckson for you.Need to replace one original port. Any suggestions on removing old port and installing new one?
Thanks Claude. Awaiting delivery of port.Indeed they are Gray ports. Cockpit facing are # 414 the others are 512. Stu has a good point not to pry and perhaps the Beckson tool might work. I used an long exacto blade to cut through the dried-up caulking. Worked OK but long and tedious if you want to make sure not to damage the gelcoat both inside and outside. The store here can get the Gray and the Beckson for you.
