D - Rings, Jacklines
Rich, This info is probably too late ,but may be helpful. A jackline should run from the bow of the boat ( either down the middle, or one down each side ) to as far aft as necessary for one to attach to it without leaving the cockpit. You can use the base of the bow cleat or a d-padeye secured with a bolt & backing plate ( NOT screws). Contrary to a couple of suggestions, it should be FLAT. A tubular jackline will roll under foot resulting in a loss of balance and possible fall overboard, or a twisted ankle. Interestingly, the preferred color is BLACK because it can be easily seen, day or night, against a light-colored deck, without need for illumination. The REI purchase suggestion is good. To prolong its lifespan, the jackline could be removed and stowed ( they are easily replaced ) when not offshore, sailing at night, nor in foul weather. ( see West-Marine, 2013 Catalogue, pg.172 for more info ).Regarding RETENTION RINGS, there should be one just outside companionway to attach to BEFORE emerging on deck. Also, one on each side of cockpit & at the helm. ( for crew & "Skipper" ). The front wall of the cockpit seats are a good accessible location. They should be BOLTED & backed by a RETENTION PLATE. Tethers should be of the DOUBLE LEASH design ( one 3 ft. & one 6 ft. "arm" ). Therefore, you can clip onto the new retention device BEFORE releasing from the current location. Hope this is helpful. All the Best to You, Wanda & Connor. Wishing You, Fair Winds & Following Seas & May Your Jib Always Draw. LT John Murphy
Safety Officer
Kent Narrows Sail & Power Squadron
PS: Rich-Wanda-er is now Saoirse ("soar-sha"; Gaelic for "Freedom" ) & flag blue w/ a red & white waterline stripe...a great boat!!
